first gen b16a into CRX wire harness?
hey guys i need some help concerning a b16 into my crx. For those of you who have done the swap before or have had the swap done... does the engine wire harness from the b16a fit into the stock dx engine harness or does the dx harness need to be reworked with the b16a wires?
also what kind of fuel pump do i need to get? i have heard that i only need the pump itself or something like that instead of buying the whole assembly.
lastly i need to know if my throttle cable will work with this motor or do i need to get one out of a 90-93 teg? ... but i have still heard that this cable is still too long and would probably need to be shortened....
You don't need a fuel pump unless you're spraying a lot of nitrous or going turbo. You will need to either modify your DX harness, or Modify the B16 harness (if you get one, usually it's not complete), either way, you have to do a DPFI to MPFI conversion. Your cable will work, but is very long for the application so it has to be wrapped around a lot. You can get the 90-93 teg throttle cable and it will work fine.
LSvtechatch97
Oct 15, 2004 04:30 AM
JapJunkie
Apr 18, 2004 11:05 PM
