Scat 95mm crank
Old Oct 23, 2005 | 08:38 AM
4piston's Avatar
Default Scat 95mm crank
Scat 95mm lightweight Crank. New never used.
$700
Old Oct 24, 2005 | 09:41 PM
4piston's Avatar
Default Re: Scat 95mm crank (4piston)
obo
Old Oct 25, 2005 | 02:57 PM
Karterguy13's Avatar
$500.00
Old Oct 26, 2005 | 06:19 AM
4piston's Avatar
Default Re: Scat 95mm crank (Karterguy13)
$600 and its yours.
Old Oct 27, 2005 | 12:34 PM
4piston's Avatar
$600 or it goes on EBAY tonight
Old Oct 27, 2005 | 07:02 PM
Blind-Fashion's Avatar
If you can get me the specs on the crank we could probably work something out
-Josh
Old Oct 27, 2005 | 07:09 PM
4NLINE UNLIMITED's Avatar
Default Re: (Blind Fashion)
Do u have to put on a Thicker Head Gasket for these to work?
Peace Chris A Town
Old Oct 28, 2005 | 05:15 AM
4piston's Avatar
Default Re: (4NLINE UNLIMITED)
No thicker gasket needed. The specs on the crank are a 95mm stroke and 29 lb weight. Its a pretty light crank and by far the best quality available in terms of materials and machining when compared to the Eagle or Crower....in my humble opinion. If the others were better, I would have bought them.
Old Oct 28, 2005 | 05:37 AM
Default Re: (4piston)
So if you bolt this crank up with a GSR Block and Stock GSR head, the Pistons arent going to hit the Head?.... My current set is a B20B Block with a PR3-3 Head. What Im building is a B17A Head with B20Z2 block..... Do you have AIM for future Questions?
Thanks Chris
Old Oct 28, 2005 | 06:12 AM
4piston's Avatar
In a stock deck block you need to run a shorter rod. This 6mm more stroke than your B20.
Old Oct 28, 2005 | 06:13 AM
4piston's Avatar
AIM is vtecluke99
Old Oct 28, 2005 | 05:32 PM
whats the rod specs and stuff like that (big end sizes) thats what i wanted to know.
Old Oct 28, 2005 | 07:12 PM
hondaballs's Avatar
the big end size is still stock size for the ls motor
Old Oct 31, 2005 | 04:57 AM
4piston's Avatar
Default Re: (hondaballs)
Yes stock LS size.
Someone better grab it, otherwise its going on EBAY this week.
nemesis.442
17
May 7, 2012 12:34 PM
dcamper24
Dec 16, 2007 12:35 PM
1991civicsi
Mar 28, 2006 07:02 AM
Chugger
Mar 3, 2006 01:22 PM
