Suspension & Brakes Theory, alignment, spring rates....
Tein S-Techs/KYB GR-2...not low
Old Oct 23, 2005 | 08:37 AM
Mushvroom's Avatar
Default Tein S-Techs/KYB GR-2...not low
I have a 92 EG, I have the set up listed above, but for some reason, it is not low as my friends eg, which ALSO has the same set up, mine is pretty much stock height. We were thinking that I might have integra suspension, the lca's and the fork and all that.
If all else fails, should I just get a set of used H&R springs?
Old Oct 23, 2005 | 09:06 AM
PIC Performance's Avatar
Default Re: Tein S-Techs/KYB GR-2...not low (Mushvroom)
Your cars share the same suspension components. How long has he had the springs on his car? its possible they sagged.
Old Oct 23, 2005 | 09:33 AM
Mushvroom's Avatar
he had the suspension for like almost a year
Old Oct 23, 2005 | 10:51 AM
IGotNoSwap's Avatar
Default Re: (Mushvroom)
his have probably sagged a lil bit over the time.
give your suspension like 2 days or so, let the shocks break in all the way.
another problem could be the bumpstops, did you cut yours? is your friend's bumptops cut?
Old Oct 23, 2005 | 11:55 AM
chrisw85's Avatar
Default Re: (IGotNoSwap)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IGotNoSwap &raquo;</TD></TR><TR><TD CLASS="quote">his have probably sagged a lil bit over the time.
another problem could be the bumpstops, did you cut yours? is your friend's bumptops cut?</TD></TR></TABLE>
if your car is sitting higher because of the bumpstops, youve got other problems on your hands.
Old Oct 23, 2005 | 06:59 PM
Mushvroom's Avatar
No, we didn't cut our bumpstops.
jrock1234
Suspension & Brakes
Jan 31, 2012 06:47 AM
DB_2o3
Suspension & Brakes
Sep 23, 2008 09:42 AM
ennah
Feb 12, 2008 05:49 AM
Drew17th
Suspension & Brakes
Jan 29, 2007 08:34 AM
i-VTEC_do_you
Aug 28, 2006 09:41 AM
