Suspension & Brakes Theory, alignment, spring rates....
mono shock front end, anti-roll
Old Oct 23, 2005 | 08:28 AM
85's Avatar
85
Default mono shock front end, anti-roll
Im in the process of designing (2 years so far) a one seater car that uses a mono shock on the front end. The idea came to me from a RC car so im sure there's a real car out there somewhere that uses a mono shock up front. I'm having trouble figuring out how im going to incorporates the anti sway setup. Any ideas?
Old Oct 25, 2005 | 03:31 PM
85's Avatar
85
Default Re: mono shock front end, anti-roll (hks85)
https://honda-tech.com/zerothread?id=1411728
Old Oct 28, 2005 | 12:17 PM
nonsense's Avatar
dunno if you got an answer, but some Formula Fords have a front mono shock
Van Diemen
Old Oct 28, 2005 | 03:23 PM
CRX Lee's Avatar
Default Re: mono shock front end, anti-roll (nonsense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">dunno if you got an answer, but some Formula Fords have a front mono shock</TD></TR></TABLE>
The Infiniti Pro Series, the support series for the IRL that is probably best known for Jason Priestley's near crippling accident, is switching from a mono-shock front suspension to a twin shock system for 2006. The IPS chassis are a spec Dallara used in the current F1 support series GP2 (previously Formula 3000, Formula Nissan, etc.).
I don't know much about the decisions but I am sure that there are various advantages and disadvantages to both shown purely by the fact that there are both systems in use although twin shock systems are by far more common. If you are looking for one "the best" system then you will probably never find a final answer.
Then there are systems with three front and two rear, two front and three rear, ...
Old Oct 28, 2005 | 08:21 PM
snowman0520's Avatar
ya the 3 shocks up front works great but is complicated to tune. the 3rd shock loads the tires more under braking getting more traction out of them but u have to be carful and not brake and turn at the same time, which u arent usualy supose to do anyways.
Old Oct 28, 2005 | 08:29 PM
85's Avatar
85
Van Diemen
Its so beautiful... thanks guys ill look more into the ford formula
espinalmotorsport
May 14, 2008 07:01 PM
CivicInspired
Honda Civic (2001 - 2005)
21
Oct 6, 2007 07:26 AM
IE_EG8
Jan 10, 2005 04:39 AM
EG_Jefro
15
Dec 6, 2004 01:16 PM
