90 Accord driveshaft trouble ??? Car wobles/vibrates after replacement of axle.
Old Oct 23, 2005 | 08:26 AM
Getsch's Avatar
Default 90 Accord driveshaft trouble ??? Car wobles/vibrates after replacement of axle.
I just replaced my left front axle on my manual 90 accord ex after having a bad boot, and now when i drive the car wobles/vibrates and is really bad under excelleration. Is the replacement axle I got bad? I put on a new tie rod end thinking that could be it cause it had some play, but that did nothing. I changed the wheel to the right side and put the right on the left and it still seems to be coming from that new axle.
So is the axle or cv bad and should i ask for a warantee replacement? or what could it be. Please any help ASAP. I need to fix this today.
Old Oct 23, 2005 | 07:35 PM
deserthonda's Avatar
Default Re: 90 Accord driveshaft trouble ??? Car wobles/vibrates after replacement of axle. (Getsch)
i would chk to make sure u got the right axle for the right year and model ( at , 5sp) .if it is , i would install a different 1 ..assuming the axle nut and the lower control arm nut are tight ...
Old Oct 23, 2005 | 07:39 PM
civicboisi's Avatar
Default Re: 90 Accord driveshaft trouble ??? Car wobles/vibrates after replacement of axle. (deserthonda)
^ that'll be my guess too...and make sure you didnt get an ABS one either
Old Oct 23, 2005 | 08:58 PM
rice_classic's Avatar
Default Re: 90 Accord driveshaft trouble ??? Car wobles/vibrates after replacement of axle. (civicboisi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicboisi &raquo;</TD></TR><TR><TD CLASS="quote">^ that'll be my guess too...and make sure you didnt get an ABS one either </TD></TR></TABLE>
What difference would that make? I though the only difference between abs axles and non abs axles is that little ring (which can be removed).??
Old Oct 24, 2005 | 09:24 AM
Honda318dx's Avatar
Default Re: 90 Accord driveshaft trouble ??? Car wobles/vibrates after replacement of axle. (rice_classic)
Where did you get the replacement? If its an autozone/advanced auto/carquest whatever REMANUFACTURED, yes, they suck and the axle is the problem..
its pricy, but RAXLES.COM is where to get quality units..
Old Oct 24, 2005 | 03:02 PM
civicboisi's Avatar
if there is a difference...maybe length too would play a role...im not sure, but they do show 2 different part numbers and i know the ABS ring is a difference...clearance issues too for the axle to hub might be a problem...again not sure, but i always ordered mine W/O the ABS if i didnt have it Price too?!
jonesEK
Apr 13, 2017 12:45 AM
BeastlyB
May 19, 2014 01:55 PM
aleks77
Dec 8, 2010 07:10 AM
b20integrapower
Feb 15, 2006 07:57 PM
Black_Accord
Jul 14, 2003 08:08 AM
