need help on swap wiring
Old Oct 22, 2005 | 11:12 PM
bbrian's Avatar
Default need help on swap wiring
hey i was wondering instead of converting to mpfi could u just buy a a whole engine harness froma obd0 si ef or DA and use that or do u have to use ur existing dx harness to do a swap
Old Oct 22, 2005 | 11:18 PM
punkdown's Avatar
Default Re: need help on swap wiring (bbrian)
Search....
The only way you could use an Si engine harness without major headaches would be if you also used the cabin harness. I don't think the DA one would work at all unless you did some major rewiring of the cabin harness.
Actually... I guess you could just convert the Si or DA harness where it meets the cabin harness, and then add the wires that are missing from the cabin harness. But to do that you would have to have intimate knowledge of both harnesses and engines, and if you had that I'm thinking you wouldn't have asked this question.
Either way though, I wish you luck dood.
Modified by punkdown at 1:42 AM 10/23/2005
Timothy Yhtomit
Feb 26, 2019 02:25 PM
rustanghunter
Mar 26, 2010 07:58 PM
bradennicely
Jul 20, 2009 03:58 AM
EF7
Sep 25, 2006 09:06 AM
91H4hatch
Sep 1, 2006 12:24 PM
