lsvtec-b16 head, how do i take out the larger plug for the oil feed???
the larger plug, intake side of the head right behind the distributor. its the one with the allen. whats the best way to take it off. i had the allen wrench in there with about a 1ft pipe over the end of it. it kinda felt like it was gonna start to strip the plug, so i stopped? what do u guys think? just get a allen socket and use an air wratchet???
I just used the allen with plenty of lot's of penetrating lube (left it over night). If you strip it, no biggie. Just drill it to use an extractor.
HTH
HTH
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bruthaboost »</TD></TR><TR><TD CLASS="quote">I just used the allen with plenty of lot's of penetrating lube (left it over night). If you strip it, no biggie. Just drill it to use an extractor.
HTH</TD></TR></TABLE>
true, didnt think about the pb blaster
ah nevermind i got it. used a breaker bar with a 8mm allen socket. just kept solid pressure on it while turning and it came out
Crx Jimmy
Aug 2, 2008 08:07 AM
