HELP!! Electrical Problems in a 92 Civic
I have a 92 Civic. The stock clock is very dim also the (+) memory for the radio doesn't work. When I hook up constant power to the clock (+) wire it lights up fine. I checked all the fuses and none were blown. It there a relay that the clock uses?? Anything else I should check??
thanks
thanks
Try a multimeter and make sure your getting power to the accesories when the key is out. I am not sure how much power you should have but I know you have to have some so the memory doesnt get erased everytime.
hoytheld
15
Mar 4, 2011 12:36 PM
