What size fitting for slave cylinder?
Old Oct 22, 2005 | 09:04 PM
Race Egr's Avatar
Default What size fitting for slave cylinder?
Im using a 3an line and i need to know if its a 10mm x1.0 or x1.25 can anyone help me out
Modified by NAPIER at 6:16 AM 10/23/2005
Old Oct 23, 2005 | 03:10 PM
paulzy's Avatar
the slave is a 1/8NPT but the connector at the firewall is a 10mmx1.0
don't quote me on that though, I haven't done a braided hydro line for slave cylinders in about 4 years
Old Oct 23, 2005 | 04:33 PM
SuperTwinz's Avatar
Default Re: What size fitting for slave cylinder? (NAPIER)
10mm x 1.0 is the correct size. That size is for both the master cylinder and slave. Also for most BMCs and Prop valves. Some BMCs use 12mm x 1.0. If you need part numbers let me know. Try to stay away from aluminum.
Old Oct 23, 2005 | 05:17 PM
paulzy's Avatar
funny, 1/8npt works with the slaves I've done in the past
Old Oct 25, 2005 | 05:01 PM
SuperTwinz's Avatar
Default Re: (paul vang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paul vang &raquo;</TD></TR><TR><TD CLASS="quote">funny, 1/8npt works with the slaves I've done in the past</TD></TR></TABLE>It will work but teflon tape is needed. Honda uses all mm or British size fittings.
alscrx
May 10, 2008 07:17 PM
alscrx
May 10, 2008 01:39 AM
macrosshn
17
Feb 4, 2006 11:30 AM
youngkow
Nov 26, 2002 01:22 PM
