ecu problem? help
I recently swaped my cx 8 valve head to a dx 16 valve head. I went to put the ecu in today and when I did the car bogs really bad at low rpms, and seems not to pull very hard. I was wondering if i would need a new o2 sensor. Or what else might be involved there?
My radio,(stock) says code on it, It won't do anything right now. When I plug the dx ecu in it runs like ****. When I have the stock p05 cx ecu it runs all right. Could it maybe the o2 sensor? I swaped heads so I have a dx head now.
DX - P06 - 4 wire O2
CX - P05 - 1 wire O2
with the P06 running a one wire O2 you will have a primary O2 code and an O2 heater code. Which will make the car run like crap.
Thanks so to convert my cx to have 4 wires for my o2 sensor I need a new o2 sensor, and then do I have to wire everything back to the ecu or is the hard ware already there just not being used?
Yes I have a 92' Cx but I just looked out there and the wire that conects to the o2 sensor is black and then goes into a clip and on the other side of the clip it has one white wire? So dose that mean that I have to run wires to my ecu?
'92s have the wires run from the ECU to the shock towers. you will have to run the wire to the shock tower plug for the heater control, the other two are 12V(yel/blk at drivers sock tower) for heater power and ground(thermostat housing) for the O2 signal.
So I don't have to run wires into my ecu? Dose any one else know how to explain it, I just don't know which wire goes ware?? Has any one ever done this before?
Can any one help me get this fixed, fully convert, motor wise my cx to a dx. I have everything but the o2 sensor and I dont know how to hook up the o2 sensor.
O2 wire color - wire color - location
black(either one) - orn/blk - passenger shock tower(14pin)
black(either one) - splice into any yellow/black - drivers shock tower(8pin)
white - white(existing white wire) - passenger shock tower(10pin)
green - splice into green/white - passenger shock tower(14pin)
accordianex
13
Mar 3, 2006 05:30 AM
jspecPR26
Aug 31, 2005 10:58 AM
jspecPR26
Aug 12, 2005 06:42 AM
civicdragger818
10
Jun 23, 2003 11:51 PM
