91 accord won't turn over
Old Oct 22, 2005 | 06:25 PM
nolo's Avatar
Default 91 accord won't turn over
My 91 Honda accord will not turnover at all. I had to push start it (manual transmission) to get it home. I checked for 12 volts at the starter solenoid and did not have it with the key held in the start position. I jumped it out and it started to crank. I'm losing the 12 volts from the ignition (start wire) somewhere. At the key cylinder I get 12 volts with the key in the start position, so I have eliminated that as being the problem. I'm guessing it goes into the fuse box at the kick panel where there is a relay. Where is the relay located? The only reason I think there is a relay somewhere is because of the clutch safety switch. If anybody can tell me the route this wire takes, I would greatly appreciate it. I tried jumping out the clutch safety switch (paper clip) to no avail.
I also checked fuse #9 at the kick panel and it is still good. Is there another fuse I should check?
Old Oct 22, 2005 | 08:05 PM
BlazeTeck2000's Avatar
Default Re: 91 accord won't turn over (nolo)
look under the dash and you will see the fuse box. the cover will tell you where the fuse is for the starter. i have auto but this happen to me and this worked. hope this helps
Old Oct 22, 2005 | 09:46 PM
nolo's Avatar
Default Re: 91 accord won't turn over (BlazeTeck2000)
Yeah, I think that is the number 9 fuse. It is labeled starter signal. I'm thinking the clutch interlock relay is in that fuse box (behind it?). Do you have a Haynes manual for a 90-91 Accord? If so, can you tell me what color the wire is after the fuse and/or the relay? I know it goes in black/white, but I'm not sure what color it is when it exits.
Old Oct 23, 2005 | 03:42 PM
i will let you know what it is ... my book is not here with me.
Old Oct 26, 2005 | 05:53 PM
nolo's Avatar
I found one on the net. The car is running good now.
Thanks
Old May 21, 2022 | 02:03 PM
cedricneys's Avatar
Thanks
what was the Problem for you i have the same issue
LISTER511
Mar 15, 2018 06:54 PM
Mason Edmison
Oct 22, 2017 09:19 AM
fivebux
Apr 9, 2013 11:01 PM
WarrenPeas
Feb 24, 2013 11:29 AM
hell_sol
10
May 11, 2011 02:10 PM
