Gains from my built bottom end?
Old Mar 6, 2002 | 08:45 PM
B19CivicHB's Avatar
Default Gains from my built bottom end?
On my 95 JDM GSR Im sending the block off for a nice dose of high CR treatment. Eagle rods, JE 12.5:1 CR pistons, balanced\blueprinted, micropolished crank. Anyone know if its really worth the 1900 im about to spend? thanks!
-Nick-
Edit: Im not trying to be a *** and ask "What will my car run in the 1\4?!?!?!" It's just that this is a sizeable investment and want to be 100% sure of its worth before I do it. thanks!
-Nick-
[Modified by B18CivicHB, 12:56 AM 3/7/2002]
Old Mar 7, 2002 | 11:06 AM
B19CivicHB's Avatar
Default Re: Gains from my built bottom end? (B18CivicHB)
anyone?
Old Mar 7, 2002 | 03:49 PM
r30slick's Avatar
are you planning on turbo? B/c for turbo you want low compression. But if not this would be a good set up for N/A.
Old Mar 7, 2002 | 05:19 PM
non-VTEC's Avatar
well going from 10:1 to 12.5:1 will yeild some nice torque and power........especially in the low-mid range area. not a whole lot in the top end though.......just little
if all your doing is having the compression increase the power will be noticable but you would kick yourself in tha *** because you just spent 1900 on this bottom end for minimal gains...............
BUT a nice strong bottom end will be benificial for later on when you decide to get some crazy high RPM cams (Toda, JUN, Skunk2) then you can really rev the **** out of that engine without worrying about the bottom end blowing up..........
i guess if you spend the cash now you wont have to worry about any problems later on.......
Old Mar 7, 2002 | 06:37 PM
B19CivicHB's Avatar
Default Re: Gains from my built bottom end? (non-VTEC)
Next winter im going to get my headwork done. Jun III's, full ferrea valvetrain, skunk2 mani, portflowed, TB matched to skunk2, 3 or 5 angle valve job etc etc.
Old Mar 7, 2002 | 06:38 PM
non-VTEC's Avatar
awesome!
Old Mar 7, 2002 | 07:54 PM
B19CivicHB's Avatar
I hope that it will put me in the high 12's on street tires. We'll see
vietxdragon
Jan 2, 2009 10:27 AM
Racersky
Nov 9, 2005 07:42 PM
mawkiemarc
Sep 28, 2005 05:43 PM
cfk182
May 17, 2005 01:35 PM
Citystar
Jun 23, 2004 06:20 PM
