Big Accord Problem...please helph
Old Oct 22, 2005 | 02:10 PM
silvestri51's Avatar
Default Big Accord Problem...please helph
I put new valve seals in my 94 Accord. they went in fine but when i was putting all the bolts back on i moved the screws that are on top of the valve springs. I just need to know where they belong or if anyone knows what i should do or if im gunna need to get it professionally fixed........
Old Oct 22, 2005 | 04:51 PM
Ghostyman's Avatar
Default Re: Big Accord Problem...please helph (silvestri51)
Do you mean the ones with a locknut over each valve? If you moved those, you'll have to do a valve adjustment to reset them to the proper clearance. It isn't very hard to do.
Old Oct 22, 2005 | 05:53 PM
P_Adams's Avatar
Not as big problem as you might think. and
"the heep"...(pause)...was correct, from where I sit.
It's not a big thing, but it has to be done correctly; or you could end up with either a terribly noisy motor, or engine skips and burned valves.
Now might be the time to anticipate picking up a service repair manual (Helms, etc)
You'll need a set of "Feeler Gauges" (available from Craftsman, Snap-on etc), an open end / box wrench and the correct screwdriver.
You will also need the patience of Jobe.
P
Old Oct 22, 2005 | 08:45 PM
Default Re: Big Accord Problem...please helph (the heep)
yea exactly...how do i know when they are correct do i have to keep going back and trying until it is pefect.
Old Oct 22, 2005 | 09:10 PM
P_Adams's Avatar
No, It's a one shot deal if you do it correctly from the beginning. It involves:
1) Positioning the cam lobe for who's follower you're adjusting to the full-closed position.
2) Setting a pre-determined space between the adjuster screw/valve stem. (Use afore-mentioned "Feeler Gauge" and Hand tools)
Infinitum
Infinitum
Infinitum
Now, I can not stress this enough.
Beg, Borrow or photo copy the instructions from a service manual for your car. If you insist on doing this (and other stuff on your car), break down and buy a manual.
P
Old Oct 23, 2005 | 12:44 PM
Default Re: Big Accord Problem...please helph (P_Adams)
i got a manual and it doesnt say how they have to be adjusted. dik...any other tips you know about it???
Old Oct 23, 2005 | 01:09 PM
deserthonda's Avatar
like P says u need to adjust the valve lash.....intakes at .010 exh at .012 ..put cylinder at # 1 top dead center and adjust # 1 valves, spin motor preferibly with rachet, extension and 19mm socket , if u spin it toward frt pf car # 3 will be up after # 1 then 4 then 2 ....to make sure when u are at top dead 3 there are notches on the back side of camshaft puley when they line up even with the head u r at either 1 or 4 , when they are perpendicular with the head u r at 2 or 3 ... i would start at # 1 makes the job easier
spartans2
Mar 9, 2011 08:36 AM
shortlid
Jan 28, 2011 06:22 AM
FireSarge
Mar 10, 2009 03:23 PM
davelux
Mar 21, 2006 06:24 PM
