wow..Really wierd electric problem...No key...fuel pump primes...dash lights on?
I have a 92 civic....and i put an h22 in it...and whats wierd is when theres no key in the ignition the dash lights are on(check engine,brake,trunk)...and the fuel pump primes..all this with no key in the ignition...gotta disconnect battery or the car will die....and when i flash high beams ...i flash it the right high beam goes on...then i flas again right turns off ...then left high beam goes on.....anyone have any ideas of what can be doing this.....all the engine harness is done right...but im really puzzled
sounds like you got a predicament there wish i could help you out bump for someone who knows
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD »</TD></TR><TR><TD CLASS="quote">i had this happen once... turns out we plugged the clock plug into the hazard light button....weird huh?</TD></TR></TABLE>
weird i had both unplugged when i got the shell...i'll look into that 2morrow..
edit:
come to think of it, doesnt the ecu and everything reset if you pull the clock fuse? this will make pretty good sense if it does??
edit:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tallyturbo »</TD></TR><TR><TD CLASS="quote">bump cuz it sucks to have a car down
thanx bro
</TD></TR></TABLE>thanx bro
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WrongWD »</TD></TR><TR><TD CLASS="quote">haha i totally almost called it....</TD></TR></TABLE>
yeah close enough lol
SeaBass
Jul 1, 2003 06:10 PM
