Suspension & Brakes Theory, alignment, spring rates....
got a quick question from my gc and koni install.
Old Oct 22, 2005 | 01:25 PM
tvrsir's Avatar
Default got a quick question from my gc and koni install.
i just install gc 500lbs front and 550 rears on my 93 hatch, i went with 8 inch front and 7 rears. after the install and everything, i set the car height and everything went well. it drives like it's on jackstands.
but my question was why does it look like i only have anout 1.5-2 inches of shock travel before it hits the bump stops? i did cut the stops in half and did not use the dust boots and i for sure did not slam the car. it sit with about 1.5i inch wheel to fender gap, front and rear.
just wondering if this is normal? as i really never looked at my old setup before.
Old Oct 22, 2005 | 05:55 PM
tvrsir's Avatar
Default Re: got a quick question from my gc and koni install. (tvrsir)
seriously man wtf happen to honda tech no more knowledgable people to answer this question, or all yall ******* lazy to type. i guess i put this in the fing wrong forum
Old Oct 22, 2005 | 06:06 PM
.water's Avatar
8and 7 inch??? wtf!!??how the hell lower car 8-7inch?? you have 10inch rota? w/o bumpers and side?
<U>
your too low and your spring is too siff for street.
</U>
Old Oct 22, 2005 | 06:29 PM
tvrsir's Avatar
Default Re: got a quick question from my gc and koni install. (Zzz GSR zzZ)
you a retard, i guess you can't help me either. seems like you haven't been around long enough young buck to understand that i have 8 inch tall springs fronts, and 7 inch tall rears. got it? good!! now let some real people who know this stuff answer my question.
also no i'm not too low and no it's not to stiff, take your pantsy *** to bed. this car is built for a purpose, it's not a ******* commuter.
Old Oct 23, 2005 | 09:15 AM
princebunta's Avatar
What spring perch is your koni yellows on? And how far up are you on the collar sleeve?
In fact, how tall is your collar sleeve? And did you see the 7 and 8 printed on your spring to make sure they are the correct lenghts.
Finally can you post pics of your suspension and we can take a better look at it.
Thanks,
Tim
Old Oct 23, 2005 | 01:24 PM
sirg-vtec's Avatar
Default Re: got a quick question from my gc and koni install. (princebunta)
Or go some top hats. They will increase suspension travel about 1 inch.
Old Oct 23, 2005 | 02:20 PM
.water's Avatar
Default Re: got a quick question from my gc and koni install. (sirg-vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sirg-vtec &raquo;</TD></TR><TR><TD CLASS="quote">Or go some top hats. They will increase suspension travel about 1 inch.</TD></TR></TABLE>
its 24mm. so waste of money. just dont slam too much
Old Oct 24, 2005 | 11:31 AM
ohjolt2's Avatar
Dude 24mm= about an inch. 25.4 mm=one inch exact. this isnt worth being stupid about.
Once thing to note is that one inch of shock travel is not one inch of wheel travel. dont forget the motion ratio.
Old Oct 24, 2005 | 12:46 PM
AutoXer's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tvrsir &raquo;</TD></TR><TR><TD CLASS="quote">but my question was why does it look like i only have anout 1.5-2 inches of shock travel before it hits the bump stops? i did cut the stops in half and did not use the dust boots and i for sure did not slam the car. it sit with about 1.5i inch wheel to fender gap, front and rear.
just wondering if this is normal? as i really never looked at my old setup before.</TD></TR></TABLE>
I was thinking the same thing when I installed mine. Turns out that there really only was about that much shock travel.
That's why Koni started offering the shortened shaft shocks off the shelf, and GC developed the tophats.
bopbop93030
Suspension & Brakes
Jan 17, 2009 08:53 PM
klion22
Feb 7, 2008 07:54 PM
95civhb
Suspension & Brakes
Jan 2, 2008 04:40 PM
tvrsir
Oct 23, 2005 08:16 AM
Shadowhunter
Sep 2, 2005 11:51 AM
