Rotora 4 piston Big Brake Kit - Brand new, red calipers
Old Oct 22, 2005 | 01:17 PM
prostreetonline's Avatar
Default Rotora 4 piston Big Brake Kit - Brand new, red calipers
Catered for the performance enthusiasts, Rotora introduces its premier big brake upgrade. Fully cast and CNC machined to ensure the highest quality; Rotoras 4 piston caliper brake kit system improves the pedal feel by increasing the clamping force while utilizing the stock master cylinder to ensure stock brake balance. Using this kit, end users receive a race-proven setup performance solution combined with an appealing aesthetic application.
Contents of Rotora Brake Kit
TWO 1 piece cross-drilled and slotted vented e-coated black rotors ( 330mm or 295mm, depending on applicaiton )
TWO 2-piece cast aluminum 4-piston calipers ( red or blue caliper of your choice )
TWO anodized black caliper mounting brackets
Rotora street performance pads
Stainless Steel braided brake lines ( DOT Approved)
All systems are ABS compatible, and direct bolt on replacement to all stock front suspension systems, with 15-25 percent larger surface area compared to stock.
We have one set that a customer purchased, and found out his 15" rims were too small for these brakes. Box is opened, one rotor is mounted, but otherwise brand new, never driven on. Asking $900 shipped. Calipers are red.
You save $400!!
Solara Kid
Honda S2000
Jan 2, 2006 03:45 PM
prostreetonline
Oct 23, 2005 10:07 AM
prostreetonline
13
Apr 1, 2004 09:20 PM
