Clutch Q? Exced+Si tranny+D15B related
Old Oct 22, 2005 | 11:43 AM
SSJSubgeta's Avatar
Default Clutch Q? Exced+Si tranny+D15B related
this is my first time......doing a swap and clutch replacement.
ok I just installed a flywheel (stock/resurfaced) an Excedy clutch and clutch preassure plate. I bolted the flywheel, then the clutch and used the allingment tool, put the preasure plate on and bolted it down. Now my questions are...
1. Tranny is bolted on to the motor now, then i looked at the clutch lever, I tryed to move it up-wards to see if it moved and what not, it was so stiff i couldnt even lift it with my 2 hands, is this normal for a new clutch???? or once its broken into it will move more with ease???
2. The preassure plate, are all the bolts supposed to be fastened, tightly to hold the new clutch in, or am i supposed to leave them a little room so that it can get some room to grab and release the clutch????
thnXs in advnc.
Old Oct 22, 2005 | 12:20 PM
SSJSubgeta's Avatar
Default Re: Clutch Q? Exced+Si tranny+D15B related (SSJSubgeta)
anyone???
Brandon H.
Nov 18, 2012 09:14 AM
an2ny888
Transmission & Drivetrain
Sep 7, 2010 08:58 PM
danny98r
Jun 24, 2004 12:15 PM
Razor
Jul 19, 2002 08:33 AM
SIK IN DA HED
Sep 11, 2001 09:17 AM
