Which brake lines to use after big brake install?
I have a 93 Civic Si hatch with 4 wheel disc brakes. Last fall I installed SS brake lines at all 4 corners. This spring I upgraded the front brakes to ITR calipers and Prelude VTEC rotors.
Last week I noticed that I had worn through the passenger side front brake line. I was in need of a replacement so I installed a Goodridge SS line for a 96-00 Civic with rear drums (I am only replacing the one front line anyhow.) PN is 333-20019B.
The EK line is approx 15" long but the line I took off is 24" long. The EK line is BARELY long enough so I will be ordering a new set of longer lines.
Which kit should I order? The ones for a 92-95 Civic with rear discs or the Integra kit seeing as I have ITR brakes?
redboost10
Suspension & Brakes
Oct 30, 2008 08:55 AM
