trans problems
Old Oct 21, 2005 | 09:46 PM
BrokenRex
Guest
Posts: n/a
Default trans problems
Alright, I has b16 s21 trans, and if im in any gear I can move the shifter left and right way further than normal, and I can pop my gears in and out w/o clutch no prob, as long as the rpms match with speed. my clutch pedal is hard as **** to push down, and it seems like the clutch point changes, its hard sometimes to put it in gear, especially in 1st. I duno someone plz help me out
Old Oct 22, 2005 | 06:45 AM
therealpoorboy's Avatar
Default Re: trans problems (TuRdCrX)
sounds like you need your clutch adjusted and need some bushings for your shift linkage.
Old Oct 22, 2005 | 07:59 AM
InJ3cted's Avatar
adjust your clutch cable and see if that helps,
Old Oct 22, 2005 | 03:23 PM
BrokenRex
Guest
Posts: n/a
Default Re: trans problems (InJ3cted)
Modified by TuRdCrX at 10:03 PM 10/24/2005
JJT211
Mar 26, 2013 10:18 PM
willskillz805
Oct 11, 2009 02:35 PM
XLR8_HFX
Feb 12, 2008 08:38 AM
hurleyint1386
14
Jan 19, 2006 03:09 PM
Kevins2k
Jun 11, 2003 10:56 PM
