cylinder #3 fuel injector not pulsing... ???
the fuel injector on cylinder number 3 on my 95 acura integra ls is not pulsing... the car threw a check engine 16 (fuel injector)... the car had venom stage 1 injectors in it.... i changed the injectors out fot a set of stoch H series and found out that the injector is getting 12 volts but it is not pulsing... that means it wasnt the injetors that were bad... whats wrong with my little girl?????
sorry for not replying sooner but hurricane willma knocked out my power
but its all good everything pulled through except my prelude
So the ecu is not grounding the injector? does that mean that the ecu is bad?
.... So the ecu is not grounding the injector? does that mean that the ecu is bad?
Brycen
Mar 18, 2012 07:13 AM
