turbo question
Old Oct 21, 2005 | 07:47 PM
1.6eR_sleepeR's Avatar
Default turbo question
howdy ht peeps. i got a question if yall could help me out please. i have a b16 with type r cams. well the question is, im going turbo with this, and are the type r cams not good with boost or can they work just perfectly fine? ive heard that they have too much overlapping or sumthin. so yay or nay? thanks guys.
Old Oct 21, 2005 | 08:22 PM
Redline130's Avatar
Default Re: turbo question (1.6eR_sleepeR)
Keep them As long as you have a good tuner, you can put down good numbers with Type-R cams. Everything is in the tune. I made over 390 whp with CTR cams and a stock bottom end on 15 psi with C16.
Old Oct 22, 2005 | 03:13 PM
wow thats good numbers ur producing, im hopin to run a similar setup. but yea, i had thought about sticking with these cams or s2 stage 1's. im still not sure but ur info helped alot thanks.
b16bri
Oct 15, 2010 05:51 PM
LennyEM1
May 22, 2009 09:17 PM
SiRhatch97
Jan 13, 2008 08:13 PM
98or00gsr
Apr 23, 2007 11:14 AM
