Need Help with MPFI swap
Old Mar 6, 2002 | 07:18 PM
Hayasa15's Avatar
Default Need Help with MPFI swap
I am getting ready to start my dpfi to mpfi swap over spring break. I have the ecu and manifold with all the sensors. I still need a distributor but are there any other parts you guys would recomend while i am working on this? Is there anything i should replace now? Any suggestions that are helpful would be nice. Also is there any problems that you guys ran into that i should look out for while i am working on this?
Old Mar 6, 2002 | 07:26 PM
SiR831's Avatar
Default you doing DX to SI?
you also need fuel injector resistor box and solder all the connections and have helms etm manual handy
Old Mar 6, 2002 | 07:46 PM
CRzex's Avatar
New User
Default Re: you doing DX to SI? (SiR831)
Im also doing a MPFI swap for one of my friends, i was wondering if anyone who has done this before can tell me exactly which plugs i will need to change.
Old Mar 6, 2002 | 07:51 PM
Mugen Dom's Avatar
Default Re: you doing DX to SI? (CRzex)
ur gonna need teh fuel injecter plugs teh distributer plugs, the injecter resister box plug...
u should change the head teh dx has a smaller cam grind than the si witch will make more power get a 92-95 si head gasket its thinner and metal=higher compresion and more hp im me if u have any questions about the swap its really easy
Old Mar 6, 2002 | 08:11 PM
CRzex's Avatar
New User
Default Re: you doing DX to SI? (jdmB18hatch)
JDMB18HATCH thanks for your help, is it cool if i give you an email if i run into any problems with the swap? Thanks again bro.
Old Mar 6, 2002 | 08:12 PM
Mugen Dom's Avatar
no problem i like to help
Old Mar 7, 2002 | 05:05 AM
Hayasa15's Avatar
Where can i get the plugs? The local junkyards dont have any Si's. Sorry i have the resistor box too.
Old Mar 7, 2002 | 07:14 AM
Mugen Dom's Avatar
Default Re: you doing DX to SI? (Hayasa15)
do u have integras? accords? anything with mpfi will work for the plugs... mostly the 92 and up wont work anything below.
Old Mar 7, 2002 | 06:47 PM
Hayasa15's Avatar
so i ca use the distributor plugs and such of older tegs and accords?
Old Mar 7, 2002 | 07:15 PM
Hayasa15's Avatar
Can i get all the plugs from and hf? Do i need different plugs for the ecu?
Old Mar 7, 2002 | 08:36 PM
Mugen Dom's Avatar
hf will work fine and the ecu will plug right in u need to do some wiring at the ecu a few wires need to be cut and some added like 4 or 5 i forget right now tired
Old Mar 8, 2002 | 05:44 AM
Hayasa15's Avatar
That is good because there is an hf at my local junkyard. I was pretty sure it was 4 wire to add and then some repinning. Now i just need a new intake manifold gasket and the plugs. Anything else?
Old Mar 8, 2002 | 07:48 AM
Mugen Dom's Avatar
get teh distributer off the HF its the same as a si
Old Mar 9, 2002 | 08:38 AM
Hayasa15's Avatar
the hf is the same as the si. damn i wish i wouls have known that. thanks i am going to call them up.
crex23
May 20, 2005 02:47 AM
efit
Jan 5, 2005 01:35 PM
Layziebtnh055
Apr 15, 2004 05:40 AM
untitled
Apr 7, 2003 11:18 AM
projectcrx
Feb 17, 2002 08:48 PM
