98mm stroke in p72
Old Oct 21, 2005 | 06:42 PM
vteczone's Avatar
Default 98mm stroke in p72
has anyone or know someone uses these set up? im wondering how much modifications need to be done on the block bore area besides rid of the squiter...
searched..
Old Oct 21, 2005 | 07:35 PM
Kendall's Avatar
You'll definately need to notch the bottom of the cylinders, and it's probably necessary to run a larger than stock bore.
Old Oct 23, 2005 | 05:21 AM
vteczone's Avatar
what about the crank girdle,will i be able to use them with that big stroke?
DA9tothewheel
Engine Machining & Assembly
May 23, 2016 09:25 AM
enriquez2000
Feb 11, 2012 07:12 PM
TRUcrxEr
May 27, 2008 02:02 PM
everyonesnaturalenemy
May 24, 2007 05:03 AM
K20 EG
Jun 24, 2003 09:22 AM
