Suspension & Brakes Theory, alignment, spring rates....
My Lude Slants
Old Oct 21, 2005 | 05:50 PM
SpeedMachine's Avatar
Default My Lude Slants
I recently realized that my car slants to the left at a lower angle. I recently changed my tires and I noticed that my camber is HORRIBLE. Also, my car is dropping on neuspeed lowering springs. What do you guys think could be making the car lower on the left side? Any feedback is appreciated.
Old Oct 21, 2005 | 11:32 PM
adictionbass's Avatar
Default Re: My Lude Slants (SpeedMachine)
for some reason, most hondas i see that are just on lowering springs sit lower on the front left corner... maybe thats just me
Old Oct 22, 2005 | 09:30 AM
BA5's Avatar
BA5
Default Re: My Lude Slants (adictionbass)
It's probably because when you sit in the car, then it will even out. I've put alot of of test 'n tune time into my car, and I have my gc's set up so that the car sits slightly higher on the drivers side when I'm not in it.
Old Nov 5, 2005 | 06:15 PM
Default Re: My Lude Slants (BA5)
What do you guys suggest i do about my camber?
Old Nov 5, 2005 | 11:56 PM
kb798's Avatar
If you have really uneven tire wear, it might be a toe problem that's accelerating the wear instead. Definitely get an alignment to zero out your toe, and it certainly wouldn't hurt to fix your camber as well.
Old Nov 7, 2005 | 09:38 AM
TunerN00b's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adictionbass &raquo;</TD></TR><TR><TD CLASS="quote">for some reason, most hondas i see that are just on lowering springs sit lower on the front left corner... maybe thats just me</TD></TR></TABLE>
My Integra sat lower on the driver's side, because its heavier on that side. 52/48 left/right wieght %, at least thats what the scales said.
The uneven-ness was made even worse during corner balancing, when the driver's front was lowered even further, to help balance the cross weights.
Eh, I'm the only one that notices the car is uneven, no one can see both sides at the same time.
FlewByU352
Suspension & Brakes
12
Nov 27, 2009 06:20 AM
Wazup
Suspension & Brakes
Apr 28, 2005 07:17 AM
brg2nr
Suspension & Brakes
Jan 27, 2005 10:55 PM
chronodyne28
Oct 24, 2004 07:03 PM
crj_lll
Sep 18, 2003 05:14 AM
