Ahh clutch is on the floor
Old Oct 21, 2005 | 04:21 PM
Dsee2's Avatar
Default Ahh clutch is on the floor
I have a 92 civic hb vx my question is, what could my problem be when my clutch is on the floor? It happened twice now, I remidied it the first time by filling the clutch fluid, but it happened again. What needs to be fixed?
Old Oct 21, 2005 | 04:29 PM
Qwik_XR's Avatar
Default Re: Ahh clutch is on the floor (Dsee2)
sounds like you've got a leak, or a failing clutch master or slave cylinder...
Any visible fluid leaking anywhere?
Old Oct 21, 2005 | 04:32 PM
92civichatch1's Avatar
Default Re: Ahh clutch is on the floor (Qwik_XR)
check the slave cylinder mine did that then it went one day and i had no clutch. It went to the florr and never came back up. Got new slave and no problems. As mentioned above check clutch master. there should be a leak somewhere unless its internal in the clutch master.
Old Oct 21, 2005 | 04:36 PM
-JSpecEk*9-'s Avatar
Default Re: Ahh clutch is on the floor (92civichatch1)
that happen to me. blead the lines a few times and try it again. i had to do it a few times and drive it but its risky but thats what i had to do. jus givin my 0.02 cents here.
Old Oct 21, 2005 | 04:38 PM
LVB18Civic's Avatar
Default Re: Ahh clutch is on the floor (JDMEK-9)
Check under the dash next to the clutch pedal for fluid. I've gone through a couple of clutch masters and that's were they usually leak from my experience.
Old Oct 23, 2005 | 10:10 PM
Dsee2's Avatar
Default Re: Ahh clutch is on the floor (LVB18Civic)
Thanks for all the replies, It did it again this past weekend, I think imma take it in to get checked out, thanks again.
jlowellintegra
Nov 27, 2010 08:15 PM
hannslebo
Mar 24, 2009 01:53 PM
Gomdohree
Apr 24, 2008 06:20 AM
Lb1atx
Sep 7, 2007 05:16 AM
Greenery18
Jul 8, 2005 04:22 PM
