h22 eg radiator fan fitment
any suggestion on slim fans? I checked ebay for slim fans but no luck.. is there a h-t sponsor i could do business with for one?
I went with the 9" slim fan and it left a good amont of room with slave cylinder. I would recommend that you put the fan before the radiator to make extra clearance just in case you go turbo .
Not saying you cant put the fan behind the rad , it's just to make more room.
put the fan before the radiator to make extra clearance just in case you go turbo . Not saying you cant put the fan behind the rad
wouldnt putting the fan BEFORE the radiator and putting the fan behind the rad be the same thing?!?!???!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordm3 »</TD></TR><TR><TD CLASS="quote"> put the fan before the radiator to make extra clearance just in case you go turbo . Not saying you cant put the fan behind the rad
wouldnt putting the fan BEFORE the radiator and putting the fan behind the rad be the same thing?!?!???! </TD></TR></TABLE>
Putting the fan in front ( under core support)of the rad will give you another 1"-1 1/2" of x-tra clearance. Most slim fans are pusher/ puller type , so you can change the fan around to accomodate which side of the rad you want it on.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93hatched_projekt »</TD></TR><TR><TD CLASS="quote">
yeah your right, i put mine on the side of the stock one, should be fine, but the other side will work better imo
</TD></TR></TABLE>yeah your right, i put mine on the side of the stock one, should be fine, but the other side will work better imo
GRANT!
Oct 27, 2009 03:37 PM
jeremyrocksursox
Oct 1, 2009 07:43 AM
