GC's with Koni Yellows
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crazydave »</TD></TR><TR><TD CLASS="quote">I think they have different sleves, as they sit on a circlip</TD></TR></TABLE>
thats when you get Coils that fit on koni yellow.
since you have one for stock shock. you can use stock botom cup to make it fit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Zzz GSR zzZ »</TD></TR><TR><TD CLASS="quote">
since you have one for stock shock. you can use stock botom cup to make it fit. </TD></TR></TABLE>
What do you mean I can use the stock bottom cup? The spring perches are fixed on the stock shocks...they cannot be moved.
So if I understand correctly...the GCs designed for the stock shock will not work without an adapter because the Koni Yellows are thinner? Is that right?
wrong
if your going to run GC on koni's YOU MUST GET the correct sleeves for koni's. I like the sleeves that fit tightly on the whole damper, they call these "baby tubes" and you will need to get the sleeve and the perch for that unit.
you could give them a call and they can answer any questions. there number is on there website which is in my sig
wrong
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">
This makes more sense. So basically the GCs I have will be too loose on the Konis, and these baby sleeves make it fit properly?
Secondly, I found these rubber things in my GC box...and I don't remember where they came from for some reason....anyone know where I pulled them out from
Chillinit
Suspension & Brakes
Mar 18, 2008 11:53 PM
importdude2000
Suspension & Brakes
Jun 17, 2007 07:28 AM
ransack
20
Aug 29, 2003 10:31 AM
