the turbo piping
Old Oct 21, 2005 | 12:18 PM
cb9_MIke_F22a6's Avatar
Default the turbo piping
if i buy the turbo, wastegate, controller, manifold, and intercooler how much will the piping be?...and wat do i do have a muffler shop bend me some?
Old Oct 21, 2005 | 12:33 PM
hondabum's Avatar
Default Re: the turbo piping (cb9_MIke_F22a6)
just dep. on who and what you know, look around at all the exhaust shops and on the FI thread here on HT
Old Oct 21, 2005 | 02:28 PM
notoriousB's Avatar
you can fab your own piping with mandrel bends from JC whitney for well under $200
you can buy pre-fabbed piping but if you're not using that kit's manifold, turbo, & I/C there's no guarantee that a kit's piping will fit your setup.
Old Oct 21, 2005 | 03:50 PM
Default Re: the turbo piping (notoriousB)
do u gato weld that ****? cuz im thinkin claps will def not hold up
Old Oct 21, 2005 | 04:59 PM
iam7head's Avatar
those crush-bent Steel pipe they bent you at your local muffler shop will do you no good..
1)most turbo's inter-cooler pipes are aluminum which is much lighter
2)most quality pipes are beam rolled, which prevents your pipe from blowing off
3)crush bent restrict air flow and cause turbulence
Old Oct 21, 2005 | 05:06 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cb9_MIke_F22a6 &raquo;</TD></TR><TR><TD CLASS="quote">do u gato weld that ****? cuz im thinkin claps will def not hold up</TD></TR></TABLE>
you got it, they will not hold up, yes you have to weld "that sh-t", make sure you get the right material with the right welding machine, for aluminum pipe, you need to tig weld it together and most of the muffler shop don't have one
one advice for you, sir, don't cheap put when you going boost, they will not perform at the same level, why spend all the cash on turbo and cheap out on little things and not harness all the power?
Old Oct 21, 2005 | 06:39 PM
Default Re: the turbo piping (iam7head)
no no ...im not gona cheap it.... and no i wouldnt use crush bent for an exhaust let alone piping for a turbo. but i cant weld thats y i was asking where i can get it done
thunteg
Aug 22, 2004 04:37 PM
alltech_hybrid
Aug 22, 2004 01:13 AM
builtB20turbo
Nov 16, 2003 05:54 PM
98vtec
Oct 25, 2002 05:51 AM
Chip398193
Sep 27, 2001 10:27 AM
