grant steering wheel
hi all, ive gotta 87 crx si that has had an aftermarket grant steering wheel installed on it, the wheels nice except whoever installed it put it in crooked. My only problem is i think i need to get that center cap that holds the horn button off that wheel but i cant figure out how to do it. Even when i remove the allen bolt pattern of about 7 or 8 it still wont seperate, is there some strange way to remove grant wheels or am i just a dim light?
ok, now ive pried the horn button off, then removed the 3 screws that retain the steering wheel to the hub, the problem is the hub is not centered, how do i get it off the shaft to centre it
Could be the alignment. I've had the wheels not sit straight after an alignment. I had to take it back and have them redo it.
Sry I didn't mean to bump an old thread. I was searching for info on Grant Steering wheels and totally forgot it was an old thread.
Modified by hometheaterman at 5:37 AM 7/4/2007
ivan1985
11
Apr 23, 2008 07:28 AM
