Whats the highest recommended comp for a daily driven on 91 octane?
Old Oct 21, 2005 | 11:41 AM
Junkyard2000's Avatar
Default Whats the highest recommended comp for a daily driven on 91 octane?
Im at about 11:1 right but want to raise it some without worrying about detonating. Its a b16 with P30s and one layer gasket. And if I can raise it, should i mill the head? new pistons?
Old Oct 21, 2005 | 12:01 PM
WHITFIELD-TUNED's Avatar
DYNO-PRO
From: SoCal I.E 909, CA, where we innovate not immitate
Default Re: Whats the highest recommended comp for a daily driven on 91 octane? (Junkyard2000)
we do 11.6 all day long
Old Oct 21, 2005 | 08:26 PM
blundar's Avatar
We routinely run 12.5-12.8:1 compression here BUT we have 93 octane gas.
The cars that did well with higher compression all had bigger cams with more duration and more overlap, often accentuated by cam gear settings. Cams that didn't work well - Peak Pro Series (Toda C copy? - 81.25mm LS/Vtec w/ CTR slugs + B16 head) Cams that did work well - Skunk2 Pro1 (85mm dart/ 12.5:1 CP / ported B16 head) Buddy club 4 (84.5mm B20 / CP 12.5:1 / endyn ported head) Blox B (aka Sk2St2 / 81.5mm B18C5 / 12.5:1 CPs / portflow B16 head)
Hope that helps.
seldon
Sep 24, 2008 03:32 PM
b16motor
10
Jan 18, 2008 05:58 PM
AutoTrenz702
Dec 13, 2005 02:44 PM
b20vtech
14
Dec 8, 2005 09:52 PM
EG_Type R
Jun 25, 2004 03:23 PM
