Do i reeeealllly need to do this?
Old Oct 21, 2005 | 11:26 AM
Don Jefe's Avatar
Default Do i reeeealllly need to do this?
Hey guys, quick question
Im changing the oil on my 97 SH and tried using the 17mm socket i have and it turns out its too long. I cant get it to thread because there is something called "MCU Oil" box right across from the drain bolt. So, do i really need to go out and buy a shorter socket? Or am i just missing the ball right now? Thanks guys.
Old Oct 21, 2005 | 11:28 AM
bad-monkey's Avatar
try a wrench?
if the socket doesn't fit, it doesn't fit.
i'm using that fram easy drain system and it works pretty well, i like it.
Old Oct 21, 2005 | 01:23 PM
pentaq's Avatar
Default Re: (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">
i'm using that fram easy drain system and it works pretty well, i like it.</TD></TR></TABLE>
how does it work?
Old Oct 21, 2005 | 01:29 PM
snowblind7x's Avatar
Default Re: (pentaq)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pentaq &raquo;</TD></TR><TR><TD CLASS="quote">how does it work?</TD></TR></TABLE>
I think he's talking about the one that you only have to screw in once and then to drain it in the future you just connect this hose thing to it.
Old Oct 21, 2005 | 01:50 PM
pentaq's Avatar
Default Re: (snowblind7x)
is it kind of a bleeder?
never mind I found it.
Modified by pentaq at 12:06 PM 10/22/2005
Emerica
Sep 14, 2007 10:07 PM
g2b2
May 11, 2007 12:56 PM
Hwj_33
Sep 1, 2006 09:32 AM
Francesco
Honda S2000
17
Apr 23, 2006 07:54 AM
SpeedDreamz.com
Welding / Fabrication
15
Mar 28, 2005 11:05 PM
