HEADERS
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohc_crx »</TD></TR><TR><TD CLASS="quote">hondas dont have headers, they have a header</TD></TR></TABLE>
Not true, the V6 Hondas have headerS.
You guys are giving honda-tech a bad name
just help this guy out and if you can't don't post.
To answer your question.. it probably won't match up, but you can try. You could always have the "rotten" part of the header rebuilt at a muffler shop, it won't be the most optimum performance but it will work.
just help this guy out and if you can't don't post.To answer your question.. it probably won't match up, but you can try. You could always have the "rotten" part of the header rebuilt at a muffler shop, it won't be the most optimum performance but it will work.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SomeDude56 »</TD></TR><TR><TD CLASS="quote">YOUR ******* DUMB</TD></TR></TABLE>
*you're
Genius.
Quit acting like dicks. You know what the guy meant.
*you're
Genius.
If you both have the same motor, then yes its possible to use two different FACTORY pieces to create a header (1). But as far as an OEM header and after market header I dont know. Whats it going to hurt if you try? Just see if the flanges line up and try to bolt them together.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y »</TD></TR><TR><TD CLASS="quote">
but then your post count doesn't go up
just help this guy out and if you can't don't post.</TD></TR></TABLE>
