b16a conversion throwing vss code
Old Mar 6, 2002 | 06:15 PM
topsekret's Avatar
Default b16a conversion throwing vss code
ok no vtec is engaging i have a code 17 for vss but hey its cable not vss and i cant get the bitch to stay all the way in how do i keep this from happening
Old Mar 6, 2002 | 07:35 PM
Lsos's Avatar
Default Re: b16a conversion throwing vss code (b18vtec)
You need to plug it in for vtec to work. I don't know how exactly the ecu gets the signal, but hey....
You have to orient the tip of the cable a certain way for it to go all the way in. Just try it a couple times and it should work, then use that clip to keep it in.
Old Mar 6, 2002 | 10:06 PM
AfEn808's Avatar
New User
Default Re: b16a conversion throwing vss code (Lsos)
make sure its connected all the way in to your cluster cause if its not its going to display a vss code because your ecu is reading rpm and your not moving.
beatngyou27
26
Nov 8, 2013 06:59 AM
JustEFit
Aug 19, 2013 11:49 AM
91b18a1ls
Mar 13, 2011 10:11 PM
92integraVTECgsr
Oct 25, 2005 11:28 AM
Joebroni
May 29, 2005 12:43 PM
