BAD Vibration
Well buddie has an 88 Crx Si, he just recently dropped in a b series, and after that the car has a horrible vibration, after like 10 mph, and just gets worse at higer speeds and when he turns left the vibration seems to be not *** bad. The things that we have replaced on the car are both the axles they are brand new, and the sterring rack, but still no luck. When we jack the car up and put our hands at 3 and 9 and shake it back and forth, it has like a clunk and the wheel moves a little bit. SO is there anything else to check that could cause this vibration, its not some little vibration, its to the point where he doesnt drive the car. Any help is appreciated.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Eg_Ryan »</TD></TR><TR><TD CLASS="quote"> When we jack the car up and put our hands at 3 and 9 and shake it back and forth, it has like a clunk and the wheel moves a little bit. </TD></TR></TABLE>
do this again and figure out where the play is coming from.
it will either come from either one of the tie rod end balljoint, or the inner tie rod balljoint, steering rack bushing or pinion gearbox.
are you missing the toe rod end jamnut?
jdmstockeg6
Oct 14, 2007 09:45 PM
