*HELP* 92 accord gas tank door will not open
Old Oct 21, 2005 | 08:19 AM
STEALTHMODECOUPE's Avatar
Default *HELP* 92 accord gas tank door will not open
the cable for the release is working fine,but it wont pop the door open,i cant tell if something is missing or not,a pic would be great or any help. ive tried searching on a few honda parts websites but had no luck there. thanks guys.
adaM
Old Oct 21, 2005 | 09:19 AM
b_serious's Avatar
Default Re: *HELP* 92 accord gas tank door will not open (STEALTHMODECOUPE)
have somone hold the gas tank poper up while u push on the side that folds in...
Old Oct 21, 2005 | 10:31 AM
Gearspeed-Performance's Avatar
Default Re: *HELP* 92 accord gas tank door will not open (b_serious)
^^x2 Or prop the gas door with something if you have no one to help you.
Old Oct 21, 2005 | 11:36 AM
Honda_Accord's Avatar
Default Re: *HELP* 92 accord gas tank door will not open (GearSpeedEF7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b_serious &raquo;</TD></TR><TR><TD CLASS="quote">have somone hold the gas tank poper up while u push on the side that folds in... </TD></TR></TABLE>
i have the same problem an .... ya just do that.. thats exactly what i do
Old Oct 21, 2005 | 11:48 AM
hondamaniac1's Avatar
Default Re: *HELP* 92 accord gas tank door will not open (Honda_Accord)
I've got the same problem w/ my '92. I pull the release and then use the metal part of my key to pry the door open. Quite easy actually.
Old Oct 21, 2005 | 12:16 PM
Default Re: *HELP* 92 accord gas tank door will not open (hondamaniac1)
L0L thats exaclty what im doing and yes it does work fine,but im just curious why its not popping open,normal wear and tear??
adaM
Old Oct 21, 2005 | 01:41 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by STEALTHMODECOUPE &raquo;</TD></TR><TR><TD CLASS="quote">L0L thats exaclty what im doing and yes it does work fine,but im just curious why its not popping open,normal wear and tear??
adaM</TD></TR></TABLE>
ya i kinda wanna know why it doesnt open all the way either ..
Old Oct 21, 2005 | 02:16 PM
HondaTechPro's Avatar
The most likely reason the door is not "popping" open is the spring is probably missing or broken. It is a little tiny spring.... P Adams can probably link you to a picture of it. Cheap too.
Old Oct 21, 2005 | 03:10 PM
b_serious's Avatar
on the inside of the gas tank door there is a little spring that is supposed to push the door open when u release it, u can bend it out so that is will push the door harder open, don't bend it to where it breaks off though
Old Oct 22, 2005 | 05:52 AM
thanks for the help guys
adaM
DsevenEm2
Honda Civic (2001 - 2005)
21
Dec 10, 2007 09:14 AM
Rs-xtacy
18
Jun 24, 2007 07:21 PM
npor
Dec 7, 2006 09:19 PM
JoeDaSoto
Nov 15, 2006 08:23 AM
breyton
Nov 29, 2004 01:22 PM
