2.2L B series DIRT CHEAP Free Assembly MUST SEE
We are changing setups in our Insight and must sell this ASAP. I paid WD for all parts and I will sell for less than what I paid. I will also have the motor assembled by Stewart Engines at no cost to you, or you can take it unassembled. This motor has a good r/s ratio and was setup to make 300+whp, turn high rpm, and was setup to last.
B18B with Darton sleeves and ERL Superdeck .550 deckplate
ERL girdle
Wiseco 16:1+ custom pistons
Oliver 5.975 inch rod
Scat 95mm lightweight crank
ARP main studs
$3000 unassembled
$3500 to cover machine work and balancing, but assembly labor is free
DPR stage 6+ head with OS Ferrea valves
Ferrea springs and retainers
$1500 I have 4 grand in this head
TWM 50mm ITBs
brand new, $1400
I must sell this stuff, we are putting a larger motor in the car to run down Norris and Skunk. SERIOUS INQUIRIES ONLY call 317-902-0200.
Luke
Modified by 4piston at 8:21 PM 10/21/2005
ERL girdle
ARP main studs
$3000 unassembled
TWM 50mm ITBs
brand new, $1400
Luke
mRdUnklOw83
Oct 15, 2012 09:51 PM
