Fuel Pump Size
Old Oct 21, 2005 | 03:00 AM
jdmeg9's Avatar
Default Fuel Pump Size
what is the factory fuel pump size on a 93 civic lx?
Old Oct 21, 2005 | 05:35 AM
Jay_Sensing's Avatar
Well, I searched all over HT and found two places where it was staed as being 79lph.
I was thinking 90 but either way, it's small.
Old Oct 21, 2005 | 07:37 AM
Turbo_y8's Avatar
Default Re: (Jay_Sensing)
yea it just small thats all you need to know
Old Oct 21, 2005 | 02:04 PM
jdmeg9's Avatar
thanks i tried searching but all i could find was crap. So that means when i drop this 190 in it will be almost 3 times the size. that kinda blows the whole fuel efficiency out the window huh?
Old Oct 21, 2005 | 02:50 PM
EGmikeH22's Avatar
* B A N N E D *
Default Re: (jdmeg9)
no
your fuel pressure regulator will keep the pressure constant
you have a pressurized return system, the only time you need a new fuel pump is if the injectors are actually shooting more fuel than the pump can supply at that pressure, making the pressure go down, and the fuel flow into the cylinders go down.
Chances are you are flowing enough fuel from the stock pump, i KNOW a stock VX pump from 92 is able to push 230 WHP, so change it if you like, but save the money and buy gas.
Old Oct 21, 2005 | 03:15 PM
jdmeg9's Avatar
Default Re: (EGmikeH22)
well it has about 200000 on the chassis and i am wanting to upgrade the boost and thought about upgrading the pump
Old Oct 21, 2005 | 03:27 PM
T-RO's Avatar
When i went boost I upgraded by getting a much cheaper 2000 Si pump which is 135lph
Old Oct 21, 2005 | 03:57 PM
EGmikeH22's Avatar
* B A N N E D *
well **** if you've got that many miles, does anyone know when they sould be changed mileage-wise?
i'm just going to wait until my air/fuel is too lean up top, but im not worried.
Old Oct 22, 2005 | 11:15 AM
jdmeg9's Avatar
yeah i am not sure if the pump has ever been changed. but my A/F is still running good at idle it will drop to about the 2nd bar on lean on a non widband o2 gauge but as soon as i give it gas it goes to stoich full throttle is pretty rich because i am running the Jackson fmu as every one knows it is innaccurate as hell
Old Oct 23, 2005 | 06:26 PM
jdmeg9's Avatar
is it normal for it to lean out at idle?? mine has always done that, it is the only reason why i was thinking of changing out the pump.
civicjoe
Mar 5, 2008 12:40 PM
sircrxracer
Apr 20, 2006 12:00 PM
B16CRXT
Aug 29, 2004 11:06 PM
Lsos
Jan 16, 2003 11:56 AM
