Turbo LS/VTEC or B18
Old Oct 20, 2005 | 09:38 PM
DA_driver's Avatar
Default Turbo LS/VTEC or B18
I have a B18A that I'm planning on turboing, but I'm trying to decide if I want to do the LS/Vtec with the turbo or not. Anyone have any info that could help me decide? What would be good about each one? What would be bad about each one?
Old Oct 20, 2005 | 10:26 PM
tvman's Avatar
Default Re: Turbo LS/VTEC or B18 (DA_driver)
if you got the funds...go boost ls/vtec...other than that...search...many threads about lsvtec
Old Oct 21, 2005 | 05:04 AM
ComptonsF1NEST's Avatar
Default Re: Turbo LS/VTEC or B18 (tvman)
Boost is cheaper than ls/vtec
if u make your own kit then u can do it for under 1000
and u dont have to change the head for boost...
Old Oct 21, 2005 | 05:13 AM
Richard Noggin's Avatar
From: Good luck to this industry, you're gonna need it.
Default Re: Turbo LS/VTEC or B18 (ComptonsF1NEST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ComptonsF1NEST &raquo;</TD></TR><TR><TD CLASS="quote">Boost is cheaper than ls/vtec
and u dont have to change the head for boost...</TD></TR></TABLE>
I STRONGLY disagree with that first statement, although it does depend on what level you're taking things. IF you can make your own kit, which is typicall NOT the case since most people aren't versed in that arena, it is feasably cheaper...but you'd be using a cheap manifold, turbo, and fuel management. What about tuning? Again, it's all up to what level you're/one is willing to take it.
btw...DA driver....there are a few kits made for you I think turbonetics makes one for the DA. You really need to search and learn and figure out what it is that you are willing to spend and what your goals are. THEN and ONLY THEN can anyone give you a correct direct answer.
and another thing...DON'T SKIMP...you WILL regret it. all you have to do is read about all the folks that cheaped out on parts and well, you know what happens...
Old Oct 21, 2005 | 06:04 AM
LL2009's Avatar
Default Re: Turbo LS/VTEC or B18 (DAantagonist)
it depends how deep your pockets are? if you got the money go for it LS/VTEC/T can go wrong with either or LS/T is nice too.
JDMike418
Jan 19, 2008 07:30 AM
ekVtecPower
12
Jun 24, 2006 04:34 AM
boosted_lsvtec9
Jul 3, 2005 09:33 AM
DriveSlowHomie
Jan 26, 2005 08:59 AM
whitelsteg
Mar 6, 2004 06:11 PM
