What size (inches/mm) vacuum line for Skunk2 GSR IM (need to buy an FPR fitting)
Old Oct 20, 2005 | 09:29 PM
BlueShadow's Avatar
Default What size (inches/mm) vacuum line for Skunk2 GSR IM (need to buy an FPR fitting)
Hey guys,
I just had a quick question about what size vacuum line is used for the stock GSR FPR. Also what sized hose barb would I need because I need to buy a fitting for my Aeromotive FPR. IIRC the GSR FPR vacuum line is 5/16". Is that correct? If it is 5/16" barbed fittings are usually sized to the inner diameter size of the hose it will be connected to right?
TIA
LudeyKrus
Mar 12, 2019 01:19 PM
si92hb
Dec 11, 2004 03:33 PM
