EP3 w/ RSX Parts?
Old Oct 20, 2005 | 08:22 PM
I:_Drive's Avatar
Default EP3 w/ RSX Parts?
Not familiar with newer hondas at all..... AND I searched. DO all the toda parts for the RSX Type S work with the the stock EP3 motor?
Old Oct 21, 2005 | 07:13 AM
BarracksSi's Avatar
Anything internal with the motor (cams, etc) will not work without a head swap. The RSX-S's K20A2 and EP's K20A3 have completely different cam setups. I don't know for sure about the pistons and whatnot, but I'll guess that they'll fit.
Type-S header & cat components will fit (I've got OEM -S parts on my EP); just need to get the mounting bracket for the Type-S header. But, they'll be longer & bigger around, so you'd need to either modify the US-spec exhaust or get a JDM-spec catback designed for the Civic Type-R (Fujitsubo RM-01A in my case).
But, yeah... the Toda cams work in the K20A2's head. If you put an A2 head on an A3 block, they should work.
(now you got me thinking a bit more about my own motor plans... hmm...)
Old Oct 21, 2005 | 07:34 AM
I:_Drive's Avatar
Default Re: EP3 w/ RSX Parts? (MaggotSI)
Do you have to sleeve the block so use forged pistons then? And who makes cams for the A3?
Old Oct 21, 2005 | 09:39 PM
BarracksSi's Avatar
Don't know about sleeving the block; I'd assume that anything involving the pistons would be the same as for the A2.
The only cams I've ever heard of for the A3 are Raz's cams, which H-T member chunky helped develop using his EP3. They give about 30-40 whp.
Old Oct 23, 2005 | 11:07 AM
Kidnkorner's Avatar
Default Re: (BarracksSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BarracksSi &raquo;</TD></TR><TR><TD CLASS="quote">They give about 30-40 whp.</TD></TR></TABLE>
On a car that already has all the bolt ons
Nikos
K Series
57
Aug 16, 2006 10:28 PM
racereaper7
Jul 12, 2006 10:13 AM
bunnyrabbit
Apr 22, 2005 11:33 AM
Wattup Though 00
May 2, 2004 07:34 PM
B00ST2nR
Aug 28, 2002 04:17 PM
