Turbo, blocking access to slave cylinder on 95 Integra
Old Oct 20, 2005 | 08:18 PM
Luchini's Avatar
Default Turbo, blocking access to slave cylinder on 95 Integra
I know this is kind of a noob question but I need to replace the slave cylinder on 95 integra. The problem is I have a DRAG III turbo kit and the air filter and intake are sitting in the way and I think its connected to the turbo or at least it looks like it is. Looking around it it looks like its just connected with screws and metal zip tie looking things.
Just wondering if I would only need a screwdriver to take it off and then put it back on or is there some other tool I need or something else I need to know before just taking it off? I just got the turbo kit less then a month ago so i dont want to go messing it up or something like that.
Old Oct 20, 2005 | 08:20 PM
adictionbass's Avatar
Default Re: Turbo, blocking access to slave cylinder on 95 Integra (Altered Beast (Luchini))
ok wow.... it sounds like u have just an intake arm with a filter connected to the turbo inlet. Just use a screwdriver and take off the hose clamp and pull the intake arm and filter off. Change out ur slave cylinder and reattach the intake pipe. done
Old Oct 20, 2005 | 09:22 PM
Luchini's Avatar
Default Re: Turbo, blocking access to slave cylinder on 95 Integra (adictionbass)
Cool thanks. WAs pretty sure that was it but never hurts to ask the pros on HT.
0ptimus prime
Apr 4, 2005 10:29 PM
integlspwr2k
Mar 30, 2005 10:56 AM
Mr. Roboto
Feb 5, 2005 11:14 PM
nitrousrush
Aug 2, 2004 11:15 AM
B20-T
Jun 20, 2002 12:50 AM
