fluid spewing every where what is it DAMNIT
Old Oct 20, 2005 | 06:54 PM
Styler93GSX's Avatar
Default fluid spewing every where what is it DAMNIT
BIG problem there are two hoses right under the intake PIPE. Down on the subframe about 3-6 inches to the left(passenger side) of the rear motor mount. and I don't know where the hell these go but they were squirting out all kinds of fluid. And I can't tell what kind it is. To the best of my knowledge it looks like power steering fluid. the tubes are metal and one is a little bit bigger than vaccume tubing and the other is a little bit bigger and is about the size of a pencil
I just finished doing my motor swap Its was a 1996 h23 powered prelude. I just got finished puting a h22a4 out of a 2000 prelude into it.
Old Oct 20, 2005 | 07:14 PM
mgags7's Avatar
those connect to the vss...there should be two tubes on it to connect...
Old Oct 20, 2005 | 09:13 PM
Default Re: (mgags7)
Thanks you very much
My h22 transmission doesn't have those two tubes. But my tranny is out of a 2000 modle car.
Should I just loop the lines
Old Oct 20, 2005 | 09:22 PM
2lude4u's Avatar
Default Re: (Styler93GSX)
Yeah, if I remember right obd2 preludes don't have the PS fluid running through the VSS, so you do need to loop those two lines.
Old Oct 21, 2005 | 04:50 AM
Default Re: (2lude4u)
alright done. Thanks.
tanvan
Nov 12, 2010 04:36 PM
dust_101
Jun 12, 2006 08:33 AM
Silvteg95
Jul 30, 2005 08:54 PM
95TEG
Jun 27, 2005 01:00 PM
rmwarriors
Oct 18, 2004 11:11 PM
