Need a few parts... need part #'s or applications PLEASE!
Well, I got all of the other part numbers off of this site (thanks TheZCR.com!), but I need some other parts... I need the part number or application for these very few parts:
-Valve seals
-Piston rings
-Valve cover gasket (I'm 99% positive it's for a 90-93 LS Integra, I just want to make sure)
I want to use only Honda parts... not really going for any REAL performance, just want to freshen the motor up a little. I'm assuming the rings and main seals are the same as the D16A6 motor, but I really want to make sure; I'm buying the stuff probably this coming up Monday.
Also, the reason I'm doing this is because the car is smoking like a cropduster. I figure I need the intake gasket, the oil pan gasket, cam seals, timing belt (just for the helluvit), valve cover gasket, valve seals, and piston rings. Anything else I may need?
Thanks in advance!
-Valve seals
-Piston rings
Thanks in advance!
Need more info. What engine are you looking for parts for? Sounds like maybe you're looking for DOHC ZC parts... Wouldn't you use the D16A1 parts from the '86-'89 Integra? Just guessing there, so don't take my word for it.
Mike
Mike
oldbeefcake
Feb 24, 2004 06:36 AM
