Apexi AVC-R wiring help!!!!
Hey All,
I have a question that hopefully someone out there will be able to help me with, I have a '97 civic hatchback with a USDM '98 b18C1 (GS-R) in it and a Drag Turbo kit with a P72 OBDI ECU and obdII to obdI jumper harness (the harness wires are black, NO COLOR). Now, I want to wire up my Apexi AVC-R electronic boost controller but I haven't been able to find the correct wiring diagram that shows me what color ECU wire to splice into!
The Apex manual says wire it like this:
Red= (power) Purple= (RPM or injector Siganl) Green= (Ground) Black= (ground) Gray= (Throttle) White= (Speed Signal)
Now, I could lengthen the wires and splice all of these elsewhere but I am trying to make it look real clean like, and I don't want all the wires running back and forth from the bay to the interior. I would like to wire eveything right there at the ECU if possible! So if anyone has any helpful advice it would be greatly appreciated!! Thanks
