Pioneer Deh-p3500 cd player & 6 1/2" speakers $80.00 Shipped.
Specs for cd player
Features
MOSFET 50W x 4 (max)
XM Radio Ready
Card Remote
Rotary Volume Control (Pop-Up)
EEQ Performance Chip
3-Band Parametric Equalizer (Adjustable Level, Frequency and Q Factor)
Easy EQ (EEQ) switches 5 Factory, 2 User EQ Presets (Super Bass, Powerful, Natural, Vocal, Flat, Custom 1 and Custom 2)
Source Custom EQ Memory (Independent Custom Memory for each source)
Selectable Loudness Control (Low/Mid/High/Off)
NEW EQ-EX Feature For Enhanced EQ Effect
SFEQ (Sound Focus EQ)
Additional Independent Bass / Treble Control for Front / Rear
Subwoofer Crossover
Selectable LPF (Low-Pass Filter) (50/80/125Hz, 18dB/oct)
Selectable HPF (High-Pass Filter) (50/80/125Hz, 12dB/oct)
Sub-Out Level (-12dB to +12dB) and Phase Control
IP-Bus System Control
MCD Control
Auxiliary Input (CD-RB10 or CD-RB20 required)
S.L.A. (Source Level Adjustment)
Selectable Fader Control
Dual 2-Volt RCA Preouts (Front & Rear or Front & Sub)
Liquid Crystal Display with Multi-Color LED Backlight
Clock
Compact Disc
Disc / Track Repeat
Audible Fast Forward / Reverse
Playback Compatible with Digital CD-R and CD-RW
Disc Title Memory (48 Discs)
CD Text (MCD)
3-beam Laser Pick-Up with AGC (Automatic Gain Control)
1-bit D/A Converter with 8x Oversampling
Anti-Shock Mechanism
Chassis
Detachable Flip-Down Face with Carrying Case
Radio
NEW Supertuner IIID with Digital Processing
24-Station/6-Button (18FM / 6AM) Presets
BSM (Best Station Memory)
Up/Down Seek with Selectable Local Seek Tuning
CD Player Specifications
Anti Theft: Removable Faceplate
Preamp Outputs: 2 sets
Preamp Output Voltage: 2 volts
CD Changer Controls: Yes
Remote Control: Yes
RMS Power: 22W x 4
Peak Power: 50W x 4
CD Frequency Response: 5-20,000 Hz
FM Mono Sensitivity: 10 dBf
CD Signal-to-Noise Ratio: 94 dB
Amp Total Harmonic Distortion: n/a
Specs for Speakers
Features:
IMPP Composite Cone Woofer
High-Energy Strontium Magnet (Woofer)
Glass-Imide Voice Coil Bobbin
Conex Damper
1-5/8" Film Cone Tweeter
3/8" Dome Tweeter
Redesigned Basket For Improved Fit on GM Oversized 6 1/2" Applications
Shallow Mounting Depth for Wider Installation Coverage
Specifications:
180 Watts MAX. Music Power
35 Watts Nominal Power Handling
Frequency Response: 30Hz -28kHz
Sensitivity: 91dB (1W/1m)
4ohm Rated
http://i5.photobucket.com/albu...d.jpg
First $80.00 shipped in the lower 48.
Features
XM Radio Ready
Card Remote
Subwoofer Crossover
MCD Control
Clock
Compact Disc
Disc / Track Repeat
CD Text (MCD)
Chassis
Radio
Remote Control: Yes
RMS Power: 22W x 4
Peak Power: 50W x 4
Specs for Speakers
Features:
Conex Damper
3/8" Dome Tweeter
Specifications:
4ohm Rated
Simple
Audio / Security / Video
Nov 23, 2002 03:53 PM
