ECU problem
Old Oct 20, 2005 | 12:48 PM
CRXb18Turbo's Avatar
Default ECU problem
I switch out ECU today and it's giving me a check engine light?
Stock ECU no light...
Chipped ECU throw the light.
Haven't check the code yet.
Is it the Chipped ECU bad?
Checking for the code later
Old Oct 20, 2005 | 12:53 PM
BlackLudeSi's Avatar
Default Re: ECU problem (CRXb18Turbo)
What kind of ECU? Is it OBD1? 2? There are many reasons, need some more info are you sure its the right ecu?
Old Oct 20, 2005 | 12:56 PM
Default Re: ECU problem (BlackLudeSi)
sorry
obd0
Both ECU are PR4
Old Oct 20, 2005 | 01:03 PM
Is it an Ebay chip or did someone actually take apart the ecu and chip it for you? Do you know what program is on it?
Old Oct 20, 2005 | 01:17 PM
I brought the ecu already chipped.
The person that I brought it from said it's professional done.
I'll open the ECU when I get home in 3 hrs.
Old Oct 20, 2005 | 01:24 PM
Yea if is an OBD0 ecu there is something for sure thats messed up. Obd0 rarely trips a CEl unless something is way wrong, usually something miss wired is a swap.
Hope that helps, just pull the code super easy
Old Oct 20, 2005 | 05:48 PM
okay....
Switched by to stock... light is gone and gain power.
Chip is by Belaray ( something like that )
Seem to lose power at low RPM
Ef4doorwagon
Mar 11, 2015 05:59 PM
da9blk1
Jul 19, 2010 08:04 PM
jfields06
Dec 27, 2008 06:42 AM
z6CRXSi
Jun 7, 2005 12:41 PM
