i was racing?
Old Oct 20, 2005 | 11:57 AM
sd,integ's Avatar
Default i was racing?
ii was racing the other night and went back home,
went t sleep, next morning turn on the car let it warm up for a lil, put it in reverse and it didnt want to go in so i let it roll a lil, put in reverse and it wnt in grinding is my tranny out .all other gears work fine ,any help would be great thanx
Old Oct 20, 2005 | 12:01 PM
BlackDAy's Avatar
Default Re: i was racing? (sd,integ)
put the clutch in and put it into 4th then put it into reverse...works for me.
Old Oct 20, 2005 | 12:07 PM
fergy016's Avatar
Default Re: i was racing? (BlackDAy)
if the 4th gear trick doesn't work. Try looking under the hood and seeing if your low on brake fluid in your clutch resevoir.
Old Oct 20, 2005 | 12:21 PM
VtecAdvantage's Avatar
mine does that everyonce in a while.. i put it in first then into reverse and it goes all the way into gear
Old Oct 20, 2005 | 12:42 PM
Sic_DA_Nine's Avatar
Default Re: i was racing? (VtecAdvantage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecAdvantage &raquo;</TD></TR><TR><TD CLASS="quote">mine does that everyonce in a while.. i put it in first then into reverse and it goes all the way into gear</TD></TR></TABLE>
i do that every time i reverse!!
Old Oct 20, 2005 | 12:55 PM
BlackLudeSi's Avatar
Default Re: i was racing? (97dC4)
Yup me to.. first then reverse its a common problem
Old Oct 21, 2005 | 11:43 AM
MugenDC4's Avatar
Default Re: i was racing? (BlackLudeSi)
same here first then reverse. If not try fourth then reverse.
Old Oct 21, 2005 | 11:47 AM
1997GS-R's Avatar
what is it about damn reverse that it's always hard to get into? i've always wondered that
Old Oct 21, 2005 | 11:53 AM
rockdude14's Avatar
i have the same problem too
god i hate reverse
Old Oct 21, 2005 | 12:55 PM
cleanDA9's Avatar
i don't even have to put it into a different gear. if i'm on a bit of a slope i just barely let off the brake, stop, then put it into reverse. doesn't matter which direction i go.
Old Oct 21, 2005 | 01:09 PM
BSP-DC2
Guest
Posts: n/a
possibly could be a clutch issue since you were probably pretty hard with it... would it go into other gears?
Old Oct 21, 2005 | 01:14 PM
cheaphonda's Avatar
Default Re: (BSP-DC2)
hahaha, i do the 4th gear then reverse too!
i always thought it was my throw-out bearing going bad though, which i still havent gotten around to fixing
00IntegrAllmotoR's Avatar
HT Black OPs
have had that happen to me also, nothing big i just put it into a different gear then throw it in reverse
Old Oct 21, 2005 | 01:31 PM
JDM-EJ1's Avatar
All Hondas do this if you put them into reverse right off the bat. Put it into 1st gear first. This happens on my Civic with 25,000 miles on the tranny, and my Accord with 187,000 miles on the tranny. Get used to it.
Old Oct 21, 2005 | 01:35 PM
CzA's Avatar
CzA
Default Re: i was racing? (JDM-EJ1)
LMAO, this is all too true. I just pp it in first roll for a split second, and throw it back in fourth and works fine all the time......Funny i thought i was the only one. LEarn something new all the time..
PEace.........
Old Oct 21, 2005 | 01:59 PM
JDM-EJ1's Avatar
Default Re: i was racing? (CzA)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CzA &raquo;</TD></TR><TR><TD CLASS="quote">LMAO, this is all too true. I just pp it in first roll for a split second, and throw it back in fourth and works fine all the time......Funny i thought i was the only one. LEarn something new all the time..
PEace.........</TD></TR></TABLE>
This has happened on EVERY DA, DC, EK and EG car that I've ever worked with or who have had friends who have owned them. It's a Honda thing.
Old Oct 21, 2005 | 04:22 PM
halozero's Avatar
Default Re: i was racing? (verbol axsassin)
1st/4th =&gt; R here as well.
always wondered what the deal was but never question it..
Old Oct 21, 2005 | 05:02 PM
Kendall's Avatar
Call me strange, but I've always gone from second to reverse.
Old Oct 21, 2005 | 05:11 PM
dudefella's Avatar
happens to me in my DA sometimes... what i do is let the clutch out halfway then try again. doesn't always work the first time, but 2-3 tries and it'll go in gear. that grinding sound sure doesn't sound too good does it
Old Oct 22, 2005 | 07:09 AM
DAcraze's Avatar
Default Re: i was racing? (dudefella)
my problem too. 1st then revearse.
Old Oct 22, 2005 | 07:12 AM
Default Re: (1997GS-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1997GS-R &raquo;</TD></TR><TR><TD CLASS="quote">what is it about damn reverse that it's always hard to get into? i've always wondered that</TD></TR></TABLE>
its because reverse isn't syncronized like all the other gears, that and their toothed gears unstead of hellical - thats why it makes a whining noise when you're backing up
Old Oct 22, 2005 | 07:21 AM
ghostrider dc2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00IntegrAllmotoR &raquo;</TD></TR><TR><TD CLASS="quote">have had that happen to me also, nothing big i just put it into a different gear then throw it in reverse</TD></TR></TABLE>
hahah problem solved!
Old Oct 22, 2005 | 08:32 AM
Moogen Powah's Avatar
Default Re: i was racing? (ghostrider dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlackDAy &raquo;</TD></TR><TR><TD CLASS="quote">put the clutch in and put it into 4th then put it into reverse...works for me. </TD></TR></TABLE>
And if I remember correctly, it says to do this process in the owner's manual (91 Integra).
Old Oct 22, 2005 | 09:22 AM
92integraVTECgsr's Avatar
no.. exactly what they said. I think it only grinds when you are rolling back and try to stick in in reverse. it needs to be put in gear first.
if its stuck and putting it into 4th first doesnt work, put it in 1st just inch it forward, then put it back in reverse.
Old Oct 22, 2005 | 09:52 AM
98GSRrdr's Avatar
I get this problem every now and then but ive never tryed the 1st or 4th gear trick .. i just let the clutch out alittle bit and it will go right in the grinding sound also happens when the car revs up and u try to put it in gear or when the car is moving and u put in in reverse
seems like everyone gets this problem once in awhile
