did search... would 89 crx si motor/harness work w/ 91 civic si?
Old Oct 20, 2005 | 10:35 AM
AZTEKEF9's Avatar
Default did search... would 89 crx si motor/harness work w/ 91 civic si?
well i did a search....and it still not clear.... i have a 91 civic si and i'm installing a 89 crx si motor/harness....need to know if i will have any problems with the harness....i'll be using a 90 si ecu?
Old Oct 20, 2005 | 11:53 AM
fast-rex's Avatar
Default Re: did search... would 89 crx si motor/harness work w/ 91 civic si? (AZTEKEF9)
yes it will just plug and play
Old Oct 20, 2005 | 12:27 PM
AZTEKEF9's Avatar
Default Re: did search... would 89 crx si motor/harness work w/ 91 civic si? (fast-rex)
everything seems to connect fine....just have to do the last connections and bolts and i'll be ready to turn it on...
but peeps say that the 88-89 are diffrent then the 90-91
Old Oct 20, 2005 | 06:33 PM
fast-rex's Avatar
I know that the some of the body molding change but I dont think that the harness changed.
Old Oct 20, 2005 | 07:19 PM
rioninja's Avatar
The 88s and some of the 89s have a different plug on the drivers side shock tower. The older plug is square, while they switched to the round syle later on.
dylaxiin
Nov 10, 2011 07:43 PM
94_civicEx
Aug 11, 2006 09:00 PM
prjctCIVIC
Jun 27, 2005 06:30 PM
chirp2hrd
10
Sep 12, 2002 10:21 AM
