Popping noise when i hit my brakes.
Old Oct 20, 2005 | 06:48 AM
92ehatch's Avatar
Default Popping noise when i hit my brakes.
ok i was going down the road last night and i hit my brakes and started to hear a popping noise coming from the front end. sounded sorta like suspension pops (its old)
also i have had bad vibration in the steering wheel lately and my boots on my axles are tore a bit.
do you think the popping is the axle and all of this is related?
thanks
btw 93 civic lx 206k miles on body
Old Oct 20, 2005 | 07:43 AM
snatch's Avatar
Default Re: Popping noise when i hit my brakes. (93egsedan)
If the boots on the axles are torn, start by replacing those. Even if it's not causing the popping, which it may be, they need to be replaced. Just get the ones from O'Reilly, Napa, Auto Zone, wherever. Shouldn't be much more than $60 or so.
If that doesn't fix it, then continue looking.
Old Oct 20, 2005 | 07:45 AM
AutoXer's Avatar
Default Re: Popping noise when i hit my brakes. (******)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ****** &raquo;</TD></TR><TR><TD CLASS="quote">
If that doesn't fix it, then continue looking.</TD></TR></TABLE>
Yeah, you need to fix the known problems you have before searching out new ones.
Old Oct 20, 2005 | 08:35 AM
92ehatch's Avatar
Default Re: Popping noise when i hit my brakes. (AutoXer)
do you think torn boots would cause my steering wheel to vibrate tho?
Old Oct 20, 2005 | 09:00 AM
litterbox's Avatar
I am a (Trial User) Army
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93egsedan &raquo;</TD></TR><TR><TD CLASS="quote">do you think torn boots would cause my steering wheel to vibrate tho?</TD></TR></TABLE>Yes.
Old Oct 20, 2005 | 10:12 AM
92ehatch's Avatar
Default Re: Popping noise when i hit my brakes. (litterbox)
ok then ill get some new ones then get good ol alignment
whp
Feb 3, 2007 08:13 AM
Calean007
Jan 27, 2005 03:36 PM
lowRIDAH
12
Dec 27, 2004 09:05 AM
Netegra2
Jul 7, 2004 08:44 AM
blacksunshine
Apr 30, 2003 05:08 PM
