Front Sway bar problem
As I was in the process of replacing my clutch and flywheel yesterday - I noticed the powder coating(the black) on the swaybar was cracked. Is this a sign telling me to replace it? or should I not worry about it.........
I ask because I know while inspecting coil springs - if the podwer coating is cracked - it means that its too worn........and should be replaced.
I also want to take this time to encourage everyone to check under your prelude - even if you have nothing to do.........just check and make sure everything's square. Make sure you're not missing a bushing or something.
I found a few things under my car that needed to be tightened - and if I were to take it to the track, my car would have taken a ****. Be safe not sorry. It only takes a few minutes to check things out - just my suggestion.
Modified by TheKingPin at 10:34 AM 10/20/2005
Jeanious
Suspension & Brakes
10
Jul 21, 2008 08:20 AM
